Heatilator CD4236IR won't light on battery backup
msmhearth
2
Sammamish WA
Hello all, I tried to start our Heatilator CD4236IR natural gas fireplace during a recent power outage. Loaded two D batteries into the tray, unplugged the transformer, and flipped the wall switch. Nothing. Repeated same steps while also unplugging the fan I separately installed years ago. Still nothing. Any suggestions? Would love to avoid the service call if possible. Fireplace works fine otherwise. Contacted Heatilator but they weren't any help. Thanks.
Lennox65
Burning Hunk
Jan 29, 2021
203
New Hampshire
I have found that the battery back up tray can be wonky sometimes. I have had to move the batteries slightly to make sure that they were in perfect contact with the contacts in the tray.
If you have a multimeter you can check to make sure that the batteries are delivering the proper voltage.
msmhearth
2
Sammamish WA
Thank you for the suggestion, Lennox65. Those batteries are pretty snug, but I will double check the voltage, that's a good idea.
