Happy Thanksgiving All, I got a efficiency question. My setup is a Jotul Oslo V2. Interior SS liner chimney, about 27-30’ high. Through some experimentation on some cold days I’ve found if I start a fire and and get my stove up to around 550-600 degrees and let it burn until it cools off to around 400 degrees and then just throw 1 or 2 small/medium splits on, leaving the air control where it is (90% closed), generally the temp will rise back up to around 500-550. It seems like I can keep the stove nice and hot all day long with this cycle versus lighting a fire and letting it burn down to coals and then starting the cycle over again.
I’ve read that it is more efficient to run the stove in cycles instead of just adding splits on throughout the day. What are your thoughts? I’m heating 1900 sq ft 2 story cape and I’ve found on cold days <30 degrees I have a hard time keeping the whole house in the 70’s by running the stove in long cycles. The upstairs rooms aren’t cold but it does take all day to get them back up to 70 after they cool off at night
