Hello all, I'm pretty much brand new here, but I've done quite a bit of reading and enjoy the challenge and rewards associated with dialing in effiency with any system.
So a licensed professional and I are installing my Pacific Energy Super insert.
We've knocked out some bricks due to an unevenness with my my hearth, and we've mortared in a flat slab for most of the insert to rest on. Messy here at the moment due to lots of soot cleaning, and wet mortar. :]
And we've very nicely wrapped up my double walled 6" machine ovaled (for clearance) liner. 1/2 inch liner... We sprayed adhesive to get the insulation to stick (with adhesive for this purpose), wapped it, cross taped the seems. Caged it, clamped the cage and spiral bound the wire mesh (cage) with stainless steel wire.
We were able to stuff it up the chimney after knocking out some interior bricks, and cutting out the old flue door frame.
So I'm excited so far, just a bit more work to go.
We are going to be using the same insulation to insulate a block off plate here.
So here is my question.
In this poorly taken photo below, can I insulate the interior of this fireplace?
I ask because from what I know about thermal transfer (I work with the the principals all of the time for automotive turbo and performance applications)...
The fireplace is under grade, the surrounding brick embedded in the ground woul have a near limitless thermal sync. Even though the brick would be heated through convection and radiation primarily which as we all know isn't nearly as effective as direct transfer would still be an limitless sync to draw heat from around the stove into the ceramic of the chimney and ultimately into the ground.
So can I physically line this with Roxul, under the stove, the walls as well as the block-off? I know Roxul is rated high for heat, but can it easily withstand DIRECT heat transfer from the stove?
Mind you the back and sides of the Pacific Energy Super insert has a mostly sealed convection steel jacket around it, so it would not be touching the physical firebox itself, I believe this goes for the bottom as well.
Is that something I'm allowed to do?
What are some other ways to insulate this fireplace? Also is there anything that the stove could physically sit on? I think Roxul is quite thick, correct? I'd need something compressible if possible.
Thanks guys!
Thanks guys!
