Would verification of the dimensions of the materials of construction be a way to authenticate a Fisher Fireplace Insert?
Is another option to compare the clearances with those recommended in the Fisher owner's Manual?
Background
I need to authenticate a Fisher Fireplace Insert which a previous home owner claims is a genuine Fisher Stove purchased in Cranbrook BC in the 1990's. The internal dimensions of the stove are 20 inches front to back and 24 inches side to side. According to the dimensions appearing in the forum, it appears to be Grandma Bear although I suppose I would need to measure the internal height of the stove to confirm.
A WETT-certified inspector could not find any certification label and issued the following conclusion:
"The installation appears to be done well with the closest distance to combustibles in 16 inches to the wooden trim on the sides of the facia. However as there is no certification label on the unit I can not determine if that clearance is enough to safely operate the unit."
A further inspection by the local Acting Fire Chief.
I have posted a photo of the front elevation view for reference.
Thank you in advance for your assistance.
Yours truly,
Ormand
Background
Yours truly,
Ormand
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/198/198165-bbd022556f7bf183d26857bf637bbd94.jpg?hash=ZhuKJQJAe5)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/198/198167-4718e54d80a20f9d6363323b03f7933c.jpg?hash=cAm-oGA__s)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/198/198166-da7465503891eec0e9fe6a1d54d832df.jpg?hash=nzDukJmL7T)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/198/198551-668a202771e2db05e9151f38ff24b54d.jpg?hash=0HXbKwQeKM)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/198/198552-7928d6dd6485f1f1034a441b809ce828.jpg?hash=qh8N2MiDbK)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/200/200145-96e8b7373f0821d962f54907efa56290.jpg?hash=qcItemaQOf)
![[Hearth.com] Help authenticating a Fisher Fireplace Insert [Hearth.com] Help authenticating a Fisher Fireplace Insert](https://www.hearth.com/talk/data/attachments/200/200146-10e85a829b71daa5ae3de415c9c22fe9.jpg?hash=naAav6kSRC)
