I have a Breckwell Big E pellet furnace. The thing has been running great, we love it.
But. It now is shutting off for no reason I can figure. It is blinking a 'code 3' which means it is out of pellets...except it isn't. We have emptied it, cleaned it out, tested the auger with no pellets and it seems to work fine. We have cleaned everything we can reach without actually opening up the stove. I am ready to toss the thing out the window as I am afraid the constant re-starting I am doing will cause another problem. I am able to start it up again, it will run for as little as 20 mins or as long as several hours. Makes.No.Sense. We use a good quality pellet, and the issue seems to be getting progressively worse.
*side note: We did have a creosote issue about 2 weeks ago, as somehow the trim came unhooked. We caught it fairly soon after it happened but had a ton of creosote build-up. Cleaned it up, but somehow something got left in a bend of the pipe and about a week later had an 'issue' in the pipe. I don't know that there was an actual fire as I saw no flames, but there was a buttload of smoke. Again, we took everything apart but the stove (the 'issue' was at the top of the pipe, away from the stove) found a couple klinkers in the bend, examined everything else we could see and all appeared to be fine. Put everything back togetehr and started the stove up and it ran fine for about 8 hrs then turned itself off.
I need help! I have no heat in my house right now except our other wood stove and not much wood left. We really depend on the Big E! And it is freezing here right now
