Harman p68 shut off issue
Do not blow back into the stove, your spouse will have your hide😋. Open the door and disconnect the vac hose and vac the stove clean. You tube leaf blower trick
I also sometimes use a Soot Eater kit attached to my hand drill for cleaning my exhaust pipes. Since my cleanout is inside (no vertical exterior run), I put the stove on "test" with the door slightly open to keep the exhaust fan going. But, make sure you are to the side because it will blow the ash out pretty well.
well i did the reverse blow out trick. i think mainly it was clogged out at the end outside. the T barely had any soot in it after doing this....and the stove was not fill with ash or anything. I couldnt even tell i did it , opening the door in the stove. I would of thought when i opened the door the stove would be cloudy with ash Nope. BUT now the stove has been running great for days now. Thanks for all the suggestion and help!!!
Glad our suggestions were helpful.
