Help... Buck 91 still stinking after several fires
Fastdonzi
208
East TN
I did all my Break in fires outside, I have done 7-8 decent fires inside and each bigger than the last.. But it keeps stinking... the wife is freaking... How many fires till a new stove stops stinking???
If the stove top has reached 500F in a burn the paint should be baked in. If this continues contact Buck. They may want to verify that the smell is paint and not smoke leakage somewhere.
I think tonight is the 1st night it has really been 500*+, tonight is the 1st time ive packed it ( 4 pieces Lol ) I believe it will eventually burn in but the wife thinks theres a problem... I'm 100% positive the pipe and the connection are good. Smells like heat/paint, not smoke... Just hoping Buck didn't have a Paint problem at some point....
Small burns will cause the smell to linger. Open the windows, get the stove up to 600F and be done with it. Put a fan blowing out a window to help exhaust fumes.
Reactions: Fastdonzi
Every time you hit a new high temp you will get a little more of the paint smell as a general rule. 500 on the stove meter, right? Where is your meter on the stove, and what temp was the cat probe reading?
Meter is right on front above the door, stove temp was 550*ish, Cat was 1600"..
I bet its paint burning off. I am getting kinda the same thing with mine. I notice the paint is still burning off on mine where the stove has the dull look now. I think your fine, just need some more burn in time.
I have a Buck 91 and did my break in fires back in the Spring. It has finally gotten cold enough where I have done 2 overnight burns. We also have a small paint smell but more than that I smell just plain old "heat" [speaking of which, the 94 is cranking out the heat]. I do not know how else to describe the smell. My stove is getting a little duller so I thing the paint is curing a tad more, just as coltfever said. I think your stove is working correctly and you do not have anything to worry about.
