Help, door gasket won't stay in
Isaac Carlson
1,143
NW Wisconsin
my dad has an outdoor boiler and we just replaced the rope gasket and used the tube of glue that came with it for the install. We used a wire wheel to clean the channel before gluing. The bottom of the gasket came loose after 2 days of burning. I think it is the creosote that glues the gasket to the boiler and that rips the gasket loose. He will only burn wet wood because "dry wood burns too hot". What do all of you use to put the rope in the door? Someone else said to use high temp rtv silicone.
Use high temp rtv. Lol
Seriously though that's what I put on mine, no problems. Buy it in the caulk gun tube and depending on rope size, mine is 1", use a generous amount under the rope and slather some on the ends where they meet so alittle bit is exposed to the eye with door open. Let the boiler cool down to the touch if hot and then put a plastic bag over the new rope, shut the door, and latche it. Wait 24 hours and remove plastic bag.
That's what worked for me. Good luck.
