We have an old Kodiak wood burning stove. It is quite lsrge.
We use it to heat our livingroom, kitchen, dining room and a tiny office.
Total is a 650 sq. Feet.
the trouble we are running into is that in order to not make it a sauna there, we have to run it well below a normal fire box temperture.
the result is so much creosote that it results in a need for a chimney cleaning every 30 days or a chimney fire will occur.
this is an on going problem. I need to solve this.
I should also explain that the pipe is on the back of the stove not the top. It comes out and runs horizontal for about 2-3 feet through what was a fireplace and then turns vertical and goes up to a very tall chimney. The vertical part is ( I don't know what you call it ) sort of a flexible steel rectangular type of pipe (looks like an accordion).
Most of the creosote seems to form in the horizontal pipe.
We burn only aged hard wood.
I hope someone on here knows what the true problem is and how to fix this issue. Currently we are considering getting a much smaller stove and getting rid of the old Kodiak stove. But honestly i don't know if we are on the right track.
