Help me make the switch to a gasifier (plumbing)
DeereMan
2
Hillsboro Ohio
I've been lurking here for a while and have become "hooked" at the idea of switching to a gasifier with storage from my current Shaver OWB. I like the idea of using a substantial amount less wood and having a boiler in a shed where it will be easier/warmer to fill. I have the opportunity to pick up a two year old Seton for a very reasonable price from a friend. While I know that there are newer and better units I feel the Seton will be a substantial step in the right direction. I am a little perplexed how to plumb this in as I will be making the switch to a pressurized system. I have Central boiler Thermopex running from my house to the boiler pad. In my home I have conventional pex (Non-O2 barrier) and a loop feeding a water-to-air heat exchanger in my ductwork along with a plate heat exchanger for my hot water. I am confused how to get the fill water to the Seton from the house without digging the yard up and running another water line. I understand that when i am done I will essentially have two closed pressurized loops, one boiler side and my house loop. If I put an automatic fill valve on the house loop can I put a second one on the boiler and fill the boiler from the house loop?
The second thought I had was to remove the heat exchanger from the back of the Seton and plumb my Thermopex directly into the boiler. I would just put the plate inside my house but could also put the fill valve for the boiler in the house.
I will probably install the storage tank next year but that shouldn't be a big deal to add plumbing wise and there is plenty on info on here about how to do that. I am also seeing in the Greenwood manual (being its a copy of the Seton) that you can run the boiler as an open system with a gravity tank to eliminate concerns about overheating during power outages. Which is better for this type of system?
sorry for all of the questions but I appreciate any help.
You may want to search this site for seton and greenwood, I believe there have been some unsatisfied owners.
Reactions: flyingcow
I suggest you stay with what you have now until you are able to install a tried and true quality gasser. If you continue to buy marginal quality units you will forever be playing "catch up" and will have invested twice as much as if you would have gone for quality in the first place.
Having a heat exchanger, when you don't need one.. sounds counter productive too.
What's the saying.. there's always money to do it right... the SECOND time. Go slow, plan it out.
JP
