Hi all, I've just received a Keystoker K2 boiler, that was professionally installed about a month ago. I've had some issues with it, mainly due to the installation. I have one pump per boiler, and 4 new zone valves on the propane boiler side. The coal boiler has DHW installed as well.
My main issues now are that I have a single pump on the propane boiler, along with new erie pop-top zone valves, by Schneider-Electric. Ever since the installation I've had a water hammer every time the thermostat shuts down. Sometimes this hammer noise/rattle is very slight, other times it wakes us up! The original installer kept being adamant it was air in the lines, yet I have emptied BUCKETS of water, and there is still the issue. I also just had a more reputable HVAC company come out and they said what I also learned by reading online - the hammer is from the very fast closing of the zone valves.
I can find no information on these valves online - is it possible to modify them to make them close slower, just as others have stated about Honeywell? What is the least expensive option to eliminate the water hammer issue, the HVAC company said possibly some sort of water hammer arrestor? Will that work with a boiler?
My other issue is over-heating. I have the K2 set for 160 low limit, 180 high. Many times after the boiler fires up to compensate for DHW or calls for heat, the temperature climbs to 230 - 240 degrees, sometimes a bit higher! The emergency thermostat (forget what it's called) connected to the boiler was set for 220, but never seemed to go off. I have since determined, by manually adjusting the thermostat, that it is off by about 25 degrees as compared to the digital thermostat on the boiler. Setting it to 205 will initiate the emergency heat dump at about 230 degrees. This second HVAC company technician also said that the circulator pump on the K2 side is installed in the wrong place! He stated it could account for overheating. Apparently the dual boiler piping is not set up for circulating from the K2 to the propane boiler. I have verified this by observing the propane boiler temperature gauge being around 120 degrees or less at times when there is no call for heat, while the K2 has a clear reading of 180 and above. I mentioned the propane boiler seemed to be trying to energize to the original installer, he said he didn't know why... The HVAC company stated the propane boiler is setup as a temperature maintainer right now, which is a waste since the K2 is up to temperature.
Would rerouting the circulator pump on the K2 side make this a parallel or series installation? Will doing this allow the propane boiler to energize and take over should the coal boiler go out?
The DHW does not have much in the way of quick recovery. We tend to use it to a point where there is hardly any hot water left and it is unable to recover fast enough. This occurs with or without a call for heat. We have a 50 gal. electric water heater, with bypass controls for it and it is currently switched off.
What are my options for easily increasing the DHW capacity/recovery?
With all these issues, I've been thinking of some sort of remote monitoring and/or automation.
Is there also some device that can be installed to remotely monitor the boiler temperature? How about something that will shut down power to the coal boiler should the fire go out, and allow the propane boiler to take over?
Thanks for any input!
Kirk
Kirk
![[Hearth.com] Help on Dual Boiler setup Coal-Propane [Hearth.com] Help on Dual Boiler setup Coal-Propane](https://www.hearth.com/talk/data/attachments/142/142182-78422810b3aa5ccb1650af01df519375.jpg?hash=rCefObPQ5K)
![[Hearth.com] Help on Dual Boiler setup Coal-Propane [Hearth.com] Help on Dual Boiler setup Coal-Propane](https://www.hearth.com/talk/data/attachments/142/142225-95735522dc813cdbbec4b623545cb0cf.jpg?hash=YASm_nNhOr)
Photo Oct 23, 4 33 43 PM
Photo Oct 23, 4 33 29 PM
Photo Oct 23, 4 32 45 PM
Photo Oct 23, 4 32 37 PM
