I have bought a Kuma wood classic stove. When I asked about floor protection the certified "guy" told me to 2x4 frame the hearth and put one piece of durock ontop of plywood then just tile over it leaving about an inch by the back wall open for venting. Upon looking through the owners manual I found I need an R-value of .595. So I am concerned that the stove guy wants my house to burn down. I plan on putting 3 layers of durock solid to the wall with no vent. Wouldn't this be the safe way to go? Now for the real brain buster. I was sold Simpson duratech 6" chimney at the same store. I find myself with a square ceiling support box which is 24" tall. a roof support bracket that fastens to roof deck , 2 48" pipes , chimney cap, and extended roof brackets to hold chimney 5' above roof (high wind protection?), and a roof flashing that is flat on the upper roof side and tapers to about an inch or so at the lower side. He said to notch the raised lower portion to accomodate the ribs in my metal roofing. ok sounds good. The top of flashing (where it cones up to pipe) has no vent slots like the install instructions show. Upon closer inspection The tag on flashing says for ICC EXCEL pipe type HT.?! The store guy says he uses it on installs all the time with metal roofing. Should I go ahead and use it? maybe cut my own vent slots under storm collar? also since I have a roof support bracket I am using the square box support for an insulation shield above my ceiling Does this sound ok? How do I close off the top of the support box (it is not going to extend up onto roof deck like instructions show) so rodents don't pack it with insulation in the warm season? The stove guy had told me if I built a chase from ceiling up to under roof I would have to cut some vents in it for air flow? I am really confused. Thanks for any help figuring out this mess. Dave NOTE- Tried calling tech support for duravent.mssge says they are in the field training. 2 emails unreturned also. glad they appreciate $900+
