If it's just for a test, get a 3-4' piece of 6" light gauge warm air duct like Highbeam suggests. On a calm couple days, remove the cap and push the crimped edge of the duct into the top of the liner. Try it out during the day with a smaller fire so that you can observe the full burn cycle. You might also want to alert the fire dept that you are conducting these tests and to call first if they are receiving an alarm. (Or can the phone connection to the dept. be temporarily cut off?) If this makes little difference, then I'm with peakbagger with installing an HRV to put a slight positive pressure in the space. If it makes a notable difference then a proper, permanent chimney extension is the answer.
Can you post an exterior full house (and hillside) picture of the chimney?
Wow, every stinking time the co alarm trips the fire department and the propane people show up. Holy smokes.
I’m glad you definitively ruled out the only fossil fuel burner in the home. That’s a big step.
Do you ever smell smoke in the house? Does the chimney smoke out of the cap during a burn?
That fireview stove is not supposed to smoke. when was the last time you cleaned the cat? How old is the cat? The very short burn times are also odd. That stone stove should easily be quite warm in the morning.
Nice place! The chimney looks quite tall. Does it have one of those creosote catching screens on top? Has it been verified clean?
Neat place!
Add pipe would be my guess. As mentioned.
It might also need a rebuild. Those tall trees on the right might be hindering draft as well.
Ah yes. After the CO problem was identified we stopped using the cat for the most part in hopes of keeping the draw stronger (not that there are draw problems while the firing is burning—I just didn’t want to have to worry about whether I remembered to disengage the cat near the end of the burn or not).
The cap has a screen. I assumed it was a spark arrester/anti vermin intrusion device.
It’s due for its cleaning this year.
