Hello everyone.
I'm not new to wood burning, but I am new to EPA wood stoves.
I have an Avalon Pendleton fireplace insert installed in my masonry fireplace. This is a pretty small insert (1.3 cu-ft firebox). It has a secondary burn tube and firebrick baffle. The bricks are all good and the door gaskets are good. I don't think it was used very much. It seems to be in great shape overall.
Here are the issues I know:
1) No chimney liner. This insert has a "direct" connection to the chimney. It uses a 6" flex liner about 6 feet long to get past the old smoke chamber. There is a block off panel at the top of the old fireplace that seals up around the liner. According to the manual, this is OK, but I know it's not the right way to do it.
2) My wood is not great. We bought the house in June, so I have only had 6 months or so to get my wood together. I have 5-6 cords split and stacked that will be great next year, but this year is not going to be very good. I have some Ash that measures around 16% with my moisture meter. It burns pretty well. I also have some Hackberry, which is usually a pretty dry wood. Most of that measures 20-25%. I try to mix it in with the ash.
Now, these are the issues I have with the stove:
1) The stove seems really cold blooded. I've read that this is a common issue with EPA stoves. It's very hard to get the fire really rolling. Restarting from coals can be done, but I usually need some small kindling. It can take an hour for the fire to really get going. Leaving the door cracked does not help. It seems like it makes it worse. Sometimes leaving the air control at half way works better on start up. It actually burns pretty well with the door wide open.
2) The stove top never gets hot. I bought a thermometer and stuck it right on top in the center. I've never gotten it above 350F. Opening the air control usually make the stove top temperature go down. I can't get it above 300 unless the air control is 1/4 open or less and the fire is really rolling.
So, obviously my wood could be better. I can't do much about that. I'm not going to buy wood. My 16% ash should be good though.
There seems to be an issue with draft. I know I have draft because I never get any back puffing or smoke when I open the door. But, the air control does not seem to affect the fire the way it should (or at least the way I think it should). The fire seems to burn better when it's warmer outside. That leads me to think I have a cold chimney and it's nor drafting right. However, I still have no smoke when I open the door.
I am going to put in a full length liner as soon as I have the funds. My chimney is 25 ft tall from the fireplace in question. It's brick with a terra cota tile liner. The liner and chimney are in great condition. The chimney is on the interior of the house. About 6 feet are exposed at the top, and it's at least 2 feet above the peak. The flue measures about 6-1/2 x 11 on the inside. So, there is no possible way I could use an insulation blanket on a 6" liner. My chimney has 3 flues. I don't know if that matters. Two are for the fireplaces on the main floor and basement. The other was for the old furnace, but has been lined for our modern gas furnace.
My parents have an old Appalachian fireplace insert in their house. It has no EPA technology, but it seems to work a lot better than my insert. Their wood is never ideal either, but I never remember having to worry about the fire. It just worked.
Thanks everyone.
Thanks everyone.
