Hi, I hope that someone can give me some advice on this. This is my second season using my Heritage Hearthstone. I really like it and although it doesn't keep the house toasty warm, it stays warm enough for me. I just read in another link that the person was getting 650 to 750 degrees and that he was looking for a leak. I know that that is way too high for the Heritage, but I wonder if my stove is getting hot enough.
I have to leave the door cracked and the damper wide open to get it up to 350 degrees, then I close the door and damper down and it will "cruise" at about 300 or so. This seems too low according to other posts that I have read.
I had the chimney/installer guy, who seems very knowledgeable and honest, in to clean the chimney at the beginning of January. The stove had stopped drawing and was smoking. He said that the wire/mesh guard at the top of the chimney was covered in creosote, but he said the chimney was absolutely creosote free, just a little white ash. He said that because the chimney was high, that when the heat hit the guard, creosote covered the mesh and clogged in up. He took the guard off and said that it was fine to burn without it. I forget the name of the chimney liner, but it was a good one and guaranteed for life.
I ask him about installing a damper (I had ask when he installed the stove last year, as well), and he said that it would only cause trouble and why did I want one. Well, I couldn't think of a good answer, because I don't know why I would want one, I just don't think that the stove gets hot enough.
The stove is installed in front of a fireplace, its vented out the back of the stove, with a connector maybe 18 inches of so and then it goes up the chimney two floors and an attic, I'm not sure how high but maybe 30 feet or so. Does anyone have any ideas for me about a damper, or if this stove is getting hot enough?
Thank you.
Dottie
Thank you.
Dottie
