So I finally ponied up the money for a blower to put on the 30-NC. We made it through last year using it to heat 2500sf, but I was sort of wanting more. I have a hearth install that is a tight fit, so I bit the bullet and pulled the beast out, but the blower on, installed a full block-off plate at the lintel, and stuffed her back in there. There is just barely enough room to get one arm in behind the stove to replace the liner, so it was a serious chore.
Fast forward to this morning. I was too tired and frustrated last night to mess with a fire, so I cleaned up and went to bed. Things are cooling down here, into the low 30's at night from time to time, and the house was a balmy 60 degrees this morning. I got a fire going, built a coal bed, loaded the Englander up, got it nice and charred and started to dial things back a bit. Inside of 30 minutes I'm at 500 degrees on the stovetop and plugged in the fan.
Good lord!. 30 minutes after that I'm thinking I need to look a little more into my new problem - keeping the 30x30 living room below 80!
TIP OF THE DAY, FELLAS: If you have an Englander 30 - BUY THE FAN.
