As some of you have already read in another thread, I built a log splitter.
Recently I was splitting some large rounds when the motor expectantly stopped. At first I figured the motor seized up. Thank the Lord that wasn't the case. I pulled the motor to find that it was free and in good working order. The problem turned out to be in the pump.
When I built the splitter I didn't have room for a suction screen in the design. I flushed the oil tank with compressed air and then two gallons of oil. I added magnets to the bottom of the tank to catch any metal shavings. This apparently didn't work because the pump picked up several metal fragments which in turn locked up the pump.
After pulling the pump (sheared the key on the shaft when it locked up) I was able to work out the shavings and the pump again was turning freely. I was able to look inside the inlet and see the gears which looked intact and not chipped up so I decided to reassemble the splitter and give her a try.
I added a remote suction filter (10 micron filter for now) to avoid any future incidents. To my surprise everything functions great.
The moral if this part of my story is that you must have some sort of suction filter/screen when doing a project like this.
In continuing my function check I loaded up the splitter to check the bypass pressure and overall pump function. Everything worked GREAT. However, as you can see in the pictures below, the pump worked so well that it was able to shear all 8 1/2" carriage bolts that held the wedge to the I beam. That was scary for me and my 12 yr old son. Not to mention one of the side clamps fell on my big toe. OUCH
The second moral of this LONG story is to make sure you are using the proper strength hardware in your design.
Please work and build safely.
