I just wanted to share my OWB hookup and how i'm heating my hot tub. My boiler I got is a 90's Heatmor 200css model I traded labor from a friend for. I refurbished and cleaned it, it had sat in the woods for several years unused. I also got some brand of Thermopex from him that was also used. My system is run off one Taco 007 pump that is on the low end supply side of the boiler. It runs 65' to my house about 30" down but surfaces and goes through the back wall of my house into the furnace room. It then feeds a 24" sidearm, 40 plate ex for on demand hot water, it then goes to the hot tub ex, which is the exact same tube style as my sidearm, and then to my forced air furnace heat ex and back to the boiler.
Total loop length is roughly 300' round trip of 1" pex. With nothing calling for heat I have a Delta T of 4degrees. That is with roughly 15' of completely exposed thermopex sitting on top the ground and an outside temperature of -1F.
The hot tub I got for free and was a huge PITA to clean but has been awesome to have, kids love it! Its a 1991 Calspa and holds 1200gal of water. We keep it at 104F 24/7 and as you can see not the best cover on it. I T'd into the 2" supply line and reduced it to 1" pex that goes to the Taco 007 pump and then its reduced to 3/4" pex to the heat ex and then dumps into the 2" return line back to the tub. I completely bypassed everything to heat the tub. The only thing I use that the tub came with is the pump to run jets and clean the spa on a timer. The heat kicks on and off with a high limit aquastat T'd into the 1" pex supply just before the pump. It is a very simple system that didn't take much to get operational. It has been up and running for 2 weeks now with zero issues. The tub is always 104F and we use it quite often.
I live in central MN so we have been seeing mostly teens and even single to below zero weather. I have seen very little difference in wood consumption with hot tub added on. I have an exactly 1/2 cord rack right next to my boiler so i can keep very good track of consumption. This is my first year with the boiler so unfortunately burning green wood mostly and i'm sitting at 1/2 cord every 12 days with the temps as stated above.
If anyone has questions on how I did the hot tub I would love to help out. This site has been so helpful to me!
Thanks
