I have heard lots on here about people not liking the Hotblast series of wood furnaces due to inefficiency. My parents had a Hotblast 1400 for the last 30 years or so and then about 15 years ago upgraded to a newer Hotblast 1400 because the other one was starting to show it's age. Now my wife and I live in the house and we operate the 1400 when it gets really cold (like 0F or below).
What makes these so wood hungry? Two things i noticed between the older 1400 and this newer one is that this one has a spin draft on the ash drawer when the older one didn't and also the auto draft flapper in the main feed door has 2 small holes in it so that even when closed there is always a small amount of air that is introduced whereas the older one's main door's auto draft flapper is solid with no holes whatsoever.
If i covered the two small holes on this one, would that make it more efficient or would it burn way too slow and create even more creasote? Also, i could grind down the nubs on the spin draft knob so that it closes completely but again, would this cause issues?
Another big complaint i've read alot on here about the Hotblasts is that they create tons of creosote. Why is that? If I used it alot more than I do then i might consider getting a new, better furnace but I feel this furnace still has lots of years left at the rate I use it.
Right now with really dry wood and even turned all the way down, i only get 4 hrs or so of good heat at a time. Is there anything I could do to safely increase it's efficiency?
Sorry about all of the questions, and thank you in advance for any responses!
