We are planning to install a woodburning cast iron stove which heats the house and is the oven and water heating, in a new house. We do not know which waty to go with our flue, so would appreciate advice on this.
We have limited locations for the stove, and can either have:
The flue internal diameter is 150 mm.
For each option, the flue height will be over the supplier's minimum recommended height of 4.2 m. It will be at least 6.7 m to reach appropriate clearance from the roof.
We are growing our own firewood, which is nearing its first harvest, and plan to dry it very well before use. It is mainly eucalypt and acacia, but we have some pine, some of which is already harvested and dry. A softwood like pine is recommended by the stove supplier when lighting the fire, but a hardwood for general running.
Our climate is maritime temperate with a range of -3ºC to 35ºC at the most extreme. The woodburning would be unlikely on those warmest days!
Thanks for any help on this.
- a completely straight flue, and no seating space in the main bedroom, and have a wall that appears to bulge out randomly into the bedroom, and more space in a hallway where it is less use, - or
- have two bends in the flue, the first , 1.3 m above the top of the stove (but not visible), would be 35º from the vertical, the flue would run at that angle for 750 mm, then a bend return it back to vertical, (the bend changes where the flue passes through the next floor's structure), and have a what looks like more logical wall layout in the bedroom, and a more useful bedroom space.
![[Hearth.com] How bad are bends in flues? [Hearth.com] How bad are bends in flues?](https://www.hearth.com/talk/data/attachments/298/298216-01477cfe7321d41a86eb13f94dcf5592.jpg?hash=qUGv1Yj83A)
