How can I Improve DRAFT?
  • Thread starter Thread starter katwillny
  • Start date Start date
K
katwillny
Guest
Hey all,
Im sure this has been discussed, but for the sake of getting people talking I will start a new post. Since installing the Englander, I am having a bear of a time getting a good draft. Right out of the stove i have a 6 inch going up 3 feet to a 45 degree angle through the wall going out and up outside the house 18 feet. Would adding another 3 feet improve draft? Just thinking what i can do this summer to prepare for next winter. Changing the cap perhaps to a different style. The current cap is similar to the one below.Thanks all.
  • [Hearth.com] How can I Improve DRAFT?
That setup doesn't sound bad enough to be the source of the problem. I'm wondering if negative pressure is more the issue.
I can't remember if in your other thread on the draft problem, anyone suggested that an internal part like the baffle might be out of position and inhibiting your draft.
There's got to be a reason why. Was that flue pipe a professional install? Is the exterior flue getting too cold? Did you try opening a window to see if that improves the draft?
Come on, hearth brain trust, let's get to the bottom of this!
The chimney doesn't sound like it should be an issue to me either. Has the chimney been brushed recently?
Matt
In addition to the 18 feet, the chimney needs to extend three feet above the roof vertically at the roof's closest point (for example, where it exits the roof or passes the edge of the roof), AND be two feet above any point on the roof which is within a 10-foot radius. If there are trees or other tall structures nearby, they can also inhibit draft.
