Hello, I did a search and could not find an answer so hope this has not be asked. My old stove you just loaded it up and if it started getting to hot close the air. My new stove a 13NCP has been a great stove for putting out heat but a pain to control. I have had trouble with getting it really going during start up but think I got that under control. Last night after it had been running all day I was ready to call it a night. I had a good 3" bed of coals so added 3 good size splits to the fire one I would even call large. The air control was pulled about the normal for me 1/4 to 3/8" to get the logs going. As soon as they were flaming good and started to get charred and secondary burn going, I closed the air to just about off. Started turning lights ect. off and noticed the fire seemed to really be taking off. I closed the air off and that "did nothing" it just kept getting hotter. The secondary tubes had a nice glow and feeding the fire. Well the stove top temp was going up the flue temp was going up. I turned the blower on high and that did very little. How in the world do you shut one on these new stove down? I'm using a OAK tube going from the stove to a window. It was icy and windy last night so that might of added to the trouble. Do you think it would help to put a damper in the flue pipe? I don't think I could have a over draft problem as there is only 17' of chimney/flue above the stove. Did not have this trouble till it started getting colder out. Also if the stove gets all of it's air from the OAK can I add a damper in line with it. I really need to use the OAK as I use oxygen so that has been great getting the air from outside. At this time I don't really trust it burning at night if it is going to take off again like it did. THANKS for your help.
PS: I know that I can be a pain with all my questions, but y'all have been great.
Don
Don
