I'm looking at a used Quadra Fire 1000i, which requires a 24v thermostat to operate. No problem. But when reading the manual, I noticed that the instructions very clearly say that the white and red thermostat wires should be connected to the stove. However, as I understand it, the white wire is normally the switched power from the thermostat, the red wire is power from the thermostat transformer to the thermostat, and the black is neutral from the thermostat transformer. This means that a simple heating system would be connected to the WHITE and BLACK wires, as opposed to the WHITE and RED. Am I going crazy? Or is this maybe a simpler system than I'm used to, where you don't need a transformer and the thermostat just interrupts/allows current that the stove is already providing.
Thanks for the help, I really hope I'm not abusing the forum by asking all these newbie questions.
24V tstats are a simple switch and either allow or disallow current passthrough like you guessed at the end of your question. There are only two wires for this system and as with many 24V components +/- doesn't really matter. Granted, there are exceptions, but for the vast majority of 24V switches as long as both wires are connected you don't have much to worry about. The stat does not generally have it's own power source unless it is programmable and at that point it is just a battery to store the program and time. Hope it all works out for you.
) so I'll have my pick. Maybe now that I don't have to worry about hardwiring a transformer I'll invest in, I dunno, a dedicated laser link so I can control my stove from the ISS if it ever comes up.
