I have the Regency I1200 and was wonder how much wood should I really have to heat this winter if I were to burn 24/7. The home is roughly 800 sqft. Thanks all
davenorthshorema said:I have the Regency I1200 and was wonder how much wood should I really have to heat this winter if I were to burn 24/7. The home is roughly 800 sqft. Thanks all![]()
please keep em coming!davenorthshorema said:I had oil for my old forced hot water. It would be nice to only burn wood....i cannot believe i spent almost 2400 on oil last year. Which is why i decided on wood since my dad can get it for free and we have all the equipment out in central mass to provide us with cord wood. Whatever it takes to save money and not depend on oil. I don't think this country realizes the crisis we are in....we will see!
ControlFreak said:davenorthshorema said:I have the Regency I1200 and was wonder how much wood should I really have to heat this winter if I were to burn 24/7. The home is roughly 800 sqft. Thanks all![]()
Hi Daven,
Be sure to assess the moisture content of your wood. If your wood was cut just this summer, you'll have trouble getting much heat out of it. You'll mostly be burning wood to evaporate all the moisture in it.
If your wood is fresh, you might consider supplementing your cordwood with some of those big pressed logs that are being sold. I don't know what they're called, but you can search around for them. They're not terribly expensive and they will be crispy dry.
Gee, an 800 sq ft house will be quite toasty. Better to vent some heat than to freeze.
Dan
EngineRep said:davenorthshorema said:I had oil for my old forced hot water. It would be nice to only burn wood....i cannot believe i spent almost 2400 on oil last year. Which is why i decided on wood since my dad can get it for free and we have all the equipment out in central mass to provide us with cord wood. Whatever it takes to save money and not depend on oil. I don't think this country realizes the crisis we are in....we will see!
I'm guessing you paid between $3.00 and $4.00 per gallon. So $2400 means you used 600 to 800 gallons. You could probably burn 4 cords, replacing roughly 520 gallons. You won't get to zero oil use (hot water and very cold days or when you or not there to stoke the stove) but I'd say that would be a good goal. And you should have a warmer house too!
You might also want to see if your electric utility participates in any energy savings plans that subsidize insulation. Stove or no stove nothing compares with better insulation for a good ROI.
Hi Daven,
Dan
Adios Pantalones said:That ratio of cord to gals of oil depends, of course, on the stove efficiency, wood species, and dryness. If you're burning black locust or red oak- then a cord is worth a lot more gallons of oil than if burning red maple or white birch (or especially softwoods).
