How quick do you suppose this poplar will season inside vs outside?
saskwoodburner
479
Saskatchewan, Canada
Seeing I get told on a near daily basis what a wild and crazy party animal I am (yeah....not really) I thought I'd test a piece of poplar for fun. I'm curious how big a difference there will be for inside vs outside seasoning, for a round split in two.
I have a green unseasoned small round of white poplar, well about 6.25" x 15", that was split as close to half as I could. One chunk is 7.25 lbs, the other 7.75 lbs, although they look about the same.
How long until the inside seasoned piece will be good enough for the stove do you suppose? A month? March 2016? Next fall? I don't know either lol. One will sit in my stove room, the other in the wood shed.
I don't want to keep splitting the wood smaller and smaller, but I should be able to figure moisture content based on something? Weight of water in a cylinder shape? In any event, the rate of moisture should drop slow enough for me to figure it out by weight. Or at least tell me how much quicker the piece inside is drying out.
Our winter is about to show up, so I'll wager the outdoor piece will lose the race in a big way.
Any thoughts or musings appreciated.
According to math-volume of a cylinder, this whole piece is 460 cubic inches of wood. So, with 1728 being a cubic foot of wood, this piece is about 27 % of a cubic foot, with that being divided in 2. Each piece is approx. 230 cubic inches of wood. Now to figure weight of unseasoned poplar per cubic foot.
According to more math, each cubic foot of this wood (would) weigh about 55.5 lbs.
Obviously wood keep warmer will dry quickest - and the closer to the stove will make a difference - if its turned, that will effect the outcome - if its in the path of any air movement that will help as well as the amount of time the stove is used and how hot it runs .
my guess is March 15th 2016 the wood will have a m/c fit for burning.
bob
As soon as you split it, take a moisture reading of both pieces, then weigh them. The weight of water is a known. Weight of wood depends on subspecies, area of growth, any knots, etc etc...
Say it reads 50% off the bat. 1 gallon of water weighs 8.34 lbs. If your piece weighs ~16 lbs, you have about 1 gallon in there. Weigh it every few months on the same scale, and then you can calculate how much was lost.
Inside vs outside... I have a very wet basement, so that would obviously be a bad place for seasoning wood. It depends more on airflow and humidity content of the surrounding environment than temperature.
I just have the one piece sitting inside, but need it to warm up to take a moisture reading. I haven't figured out where in the room to put it yet. Maybe beside the couch to the wall so as to not influence it too much from the stove. And to keep it out of sight.
I know the inside piece will win by a mile, but just for fun I think it will be interesting.
The outside piece gets -10 to -40 Celsius (14 to -40 F) for temps, and the inside piece gets 60-82 F with 40 % humidity.
Is the outside piece top covered? In a windy spot? Even ice cubes in your freezer will sublimate, faster when left exposed to the air in there..
Edit: just read that it's in the wood shed.. to be fair, I'd leave this piece exposed as much as possible in there- nothing in front, back or behind it. A piece of wood in a stack will always take longer to dry than one left out.. have to compare apples to apples.
I also think the inside piece will win, especially if you have a ceiling fan running.
Oh for sure, the wood shed, on a shelf by itself.
weigh both pieces in two weeks so we can get a slope started on the data you got.
Hard to say what the true moisture is, my MM points north of 44% on this wood.
But it will be very easy to calculate the starting % when the piece stabilizes and you can use your MM on it. It probably was near 100% on the stump. You also haven't said how long since it was cut. Wood does lose water in round form, just not as quick as when split.
With respect to drying, the initial drying is very fast, then is slows down. Depending on its surface temp you should see the stove room piece lose about 2/3 of the weight that it is going to actually lose in a matter a week or so, then another 30 days for it to stabilize at the driest you can get it. So weigh it daily if you want to get a handle on what is happening, especially in the beginning.
I've seen red maple lose 43% of its weight when originally weighed within minutes of being felled, bucked and split. Poplar will probably be similar so assuming your stuff was very fresh cut I'd expect you to see final weights in the range of 4.25-4.5 pounds. Equivalent of a piece going from 90% on a dry basis (MM reading) to 8%.
5% MC difference is my guess.
I was cutting wood at the start of November, so 4-5 weeks since cut.
Just a small update, the inside piece went from 7lb 4 oz down to 5lb 7 oz Dec 15 to Jan 14, about 1.75 lb drop. I'm surprised by this weight drop, considering the wood is in the living room, out of the way of anything, hiding 15 feet away from the stove. It also has decent checking/cracks on the end grain as well. I'll check the wood shed piece later.
I think no one has mentioned relative humidity yet. If the humidity inside your home is only 30% (because of the low temps outside) and possibility of humidity outside (low temperatures hold less moisture). The wood in the house will dry darn fast.
I have a closet door with wood louvers and every winter some fall out and they stay put in the summer.
One way to know the moisture content of the wood is to weigh it during the test, then at the end of the test completely dry both pieces in an oven and weight them. Afterward you can calculate the moisture contents based on the weights you measured.
Is this something that can be done relatively safe at 170-200 f? How long should it take ballpark?
Finally weighed the outside piece, and it went from 7 lb 12 oz to 7 lb 10.9 oz...a whole 1.1 ounces lost. I suppose that's interesting in itself as the weather has been below freezing.
A bit early to call the race, but I think indoor piece is winning.:)
You want to be over the boiling point of water, but under the combustion point of wood. So higher than 212, less than 600. In academic articles I am used to reading about 250 and/or 275 dF ovens.
Ballpark, many hours. The "gold standard" seems to be to take it out of the oven, weigh it, put it back in the oven for two more hours, weigh it again and find the same weight as two hours previously.
I'll go with three days, ballpark, never tried it.
I don't really know much about the best temperature to dry wood, but there is an old thread on here somewhere that discusses drying wood in an oven. I am sure 200 degrees is safe, just not sure how long it would take to dry. I would dry it a few hours, weigh it ,then dry some more. When you can't make it any lighter you have dried away all the free moisture.
UT Knoxville put out a publication on moisture content of firewood in which they dried the wood in an oven at 220 F for 12-24 hours. Spoiler alert: "Seasoned" firewood they purchased at local stores averaged 66% MC.
I think I'll want to weigh the pieces mid Feb, then again mid March, and possibly give it a bit of oven time then. Glad my hobbies are cheap.:)
I think the outdoors sample will stabilize around the Fiber Saturation Point, about 30%MC give or take. IIRC the word for water evaporating from ice straight to a vapor is sublimation, but its been a while. Once you get all the ice sublimated out of the tubules and are at FSP I think sublimation will slow down to essentially zero.
I just had a quick look there, but some interesting reading. I knew poplar seasoned quick but I didn't realize it sublimated that much (if split) during the winter. Most of my poplar fall/early winter cut is still in rounds ready to be split. I should have split it during this cold snap, but i suppose winter's not over yet.
You're not missing much if anything. That free water is easily lost in a very short time in warmer weather. What took a couple months will happen in a week of spring.
