Same question as the subject, I don't know what to use to attach the wire mesh the the cement board so that it stays up.
			adkdadto4 said:I have the same setup
I used screws and fender washers to attach it- and made sure that the screws went through to wood behind to really hold well..
then applied scratch coat, then the backbuttered the cultured stone and applied...
D-Nic said:I did not know the lath had a right side. Thanks that tip. I'll have to go to corning website and see if I can get some clear instructions. Thanks.
Hogwildz said:Corning's installation instructions say lath on everything but bare masonry surface.
Even cement board must have metal lath.
wellbuilt home said:Ive never used that material , but have installed miles of stone over the past 30 years . You don't really have any trouble with stone work if its inside and is not subjected to the freeze thaw cycle. But I'm just speaking from 30 years of experience I haven't read any directions since the late 70s sorry guys. I stand corrected
