how to build a wall with 1 inch air space???
Don't know if this will help but the brick in my avatar is a inch or so out from the wall..and a row of brick near the top and bottom is spaced so there is air movement from top to bottom.
[Hearth.com] how to build a wall with 1 inch air space???
Wow looks great !!
I used 1 " conduit screwed to the wall in vertical fashion. I spaced 3 of them equally and then screwed my corugated steel over it. Your can see my wall in the avatar. For my other wall protector, I used the same 1 " conduit, then screwed cement board to it. Then I tiled directly on the vertical cement board. Both came out nice. Good luck.
