3 in 1 oil on the shaft closest to the motor on both sides.. did you try the stove with the top rod pulled out?
Glass should not be black within hours of start up. It is running with the vac switch jumped because we think there is still something plugged up somewhereGet used to the glass covered. It happens quick and not much you can do about it. Happy to see you are making progress on the stove.
Yes, the vac switch is still jumped.Glass should not be black within hours of start up. It is running with the vac switch jumped because we think there is still something plugged up somewhere
I oiled the conv fan. Sounds better. Still loud and whiny but not getting all those really high pitched beeps and squeals. This morning I tried starting it up and letting it do it's thing without baby sitting it. In twenty minutes the fan turned off and #3 light blinking. I used augur button to feed more pellets, hoping there were still embers in there and used the blow dryer trick on the fresh air intake. It roared back to life. And funny thing, when I did that the conv fan cut on for about 5 seconds, then turned back off.Well we will worry about a clean burn when we can get it to burn constantly first.
...Unless you want to make a road trip, which would bring you right past my place and we could go together. I'd take the Suburban, I have a finished mount sitting in Valentine, Nebraska I need to pick up anyway......I thinking it was the damper being open all the way. With it closed up it should draw through the drop tube and eliminate the smoking hopper. Without being in front of the stove we have to wait for her to execute the instructions one at a time. So far it lights and runs for more than 5 min and thats more than it has been doing. So we are making progress
Nope, not really any difference.Did it burn better with the top rod out? Try closing the intake damper till it touches the set screw
Uhhh...wish I'd known to check this when it was out of the stove. But I had air blowing out the exhaust tube when it was disconected from my stove pipe, so wouldnt it have to be?On a negative draft unit like you have THERE SHOULD NEVER BE ANY SMOKE coming through the fuel bin, ever. That is a sign the that the negative draft isn't functioning correctly and will cause a hopper fire with very bad results (like burn your house down). Why all maunfacurers went from positive draft (pressurized burn area) to negative draft (vacuum in the burn area years ago) and why it's folly to buy a used positive draft stove. Amaizeablaze comes right to mind as does the early models of the England stoves. They all belong at the metal recycling yard in my opinion.
Are you absolutely sure the combustion fan you replaced the fan wheel on is rotating in the correct direction? You can change the rotation of the motor by flipping the field laminations 180 degrees which reverses the armature rotation. The wires to the coil mean nothing, only the induced magnetic field determines the rotation and the new fan you put on has a definite direction of rotation to purge the byproducts of combustion. if it's rotating backwards it will be extremely inefficient in it's task.
I closed air intake to set screw, though it's set quite a way in there, and I'm not getting smoke in the pellet bin right now.I thinking it was the damper being open all the way. With it closed up it should draw through the drop tube and eliminate the smoking hopper. Without being in front of the stove we have to wait for her to execute the instructions one at a time. So far it lights and runs for more than 5 min and thats more than it has been doing. So we are making progress
Lol. Not even close. Valentine Nebraska is pretty much kitty-corner across Nebraska from me. I'm clear on the other side, just north of Lincoln....Unless you want to make a road trip, which would bring you right past my place and we could go together. I'd take the Suburban, I have a finished mount sitting in Valentine, Nebraska I need to pick up anyway......![]()
The ones inside against the back wall of the firebox? Or the burn pot it self?Oh, i was hoping it had a better flame.that top rod closes off a lot of air. Ok so how do the holes look in the bottom of the burn pot pic if ya can
NOPE! That isn't the glass, it's smoke...lots and lots of smoke.I dont have smoke coming out the bin, but I can see the firebox filling with smoke. Unless that's just my glass?
