So my daughter's bf just bought a house a few months back and he called me over to look at some mold that was starting to form on an inside exterior wall. I'm thinking it must have always been an issue and is now showing up now that they are living in the house and the heat is on. Anyhow the crawl space is damp. 1st thing I noticed is they had all the exterior vents blocked off. I placed a fan facing down in the crawl space entry and 2 others on one exterior wall blowing in the vents to try and dry it out. Now we need to come up with a long term solution.
1st off the exterior grade is either level or slightly angle toward the crawl space. Actually on the wall where the mold was forming it is higher as they had some type of planter with the dirt mounded up higher than the crawl space. So the question;
Can we come out 2 feet or so from the foundation and dig down 1 foot below the grade of the crawl space and fill with stone or do we need a full blown french drain? There is somewhat of a vapor barrier in the crawl space but it's not properly installed as they didn't bring it up the edges or overlap the seams. I'm thinking that the vapor barrier, stone drain and a few gutters may solve the issue. What do you think?
