Hi all,
I already have one topic at this forum about smoke leaking into my room while refilling. I've managed to have less smoke getting in my room by getting longer runs so temperature of the stove and flue is high enough before refilling. It also helps when only burning when there is enough wind (3 Bft and up is my new rule which seems an acceptable common rule found online although some use 2 Bft and up).
I started with a bottom-up method, but after a while I switched to the top down method which took some practice. I still use news papers and some alcohol to quickly make as much heat as possible. I use small pine wood on top (<1 inch diameter), about 4 pieces, and below I use 2 medium sized (still small) pieces of birch. Below I have two 'bigger' birch pieces, but still not that big as my stove box is small.
Using this method I managed to reach a burn time of 2:15 hours which is a big improvement on my previous burn time of around 1 hour. (back then I used more pine wood to start the fire and less birch wood). The only problem is temperature of the top of the stove: I'm aware I should monitor flue temp as well, but right now I have only been monitoring top of the stove temperature using a simple magnetic thermometer. It has three areas:
creosote: 0 - 270 F
best operation: 270 - 460 F
too hot: 460 - 900 F
I always try to keep stove-top temperature in the best operation region. But last time when I managed to get 2:15 hours of burning time temperature raised above 460 F. Not too much, it was around 480 F. The stove manual doesn't mention specific maximum temperatures, but after reading this interesting post about starting a fire with an EPA stove (https://www.hearth.com/talk/threads/starting-a-fire-and-running-an-epa-stove.179714/) I read about a stove-top temperature of 625 F: "The stove has been cruising for 20 minutes and is almost up to temperature. The stove top settled at 625º. The analog probe thermometer is finally catching up to the digital probe."
Is this temperature way too high - something I would think because of my thermometer (too hot)? Or is it fine for my stove (and flue)?
My burning practice:
* light fire => I get a lot of flames and heat to start the fire
* after about 5 minutes I close the door
* after about 10 minutes I close primary vent / air intake
* after about 15-20 minutes (not exactly sure about timing) I reduce secondary vent / air intake, stove top thermometer reads 270 F
* after about 20-30 minutes (not exactly sure about timing) temperature gets in the 460 F area. I reduce secondary air vent about 90%, but never close it 100% as the stove manual advices to always let some air in. But temperature keeps raising into the "too hot" area (> 460 F)
Always when temperature gets in the highest region of the best operation area, around 460 F, I start smelling stove paint. I used my stove about 15-20 times now (average of 1,5 hours per time), but I'm still smelling a distinctive smell - I guess it must be stove paint. As I'm a bit sensitive to fumes, I don't really like it (although it's not too bad). But I tend to open the window a bit more to get fresh air inside.
So is it okay to get a stove temperature of > 460 F?
creosote: 0 - 270 F
![[Hearth.com] How to run my Morsoe 1412 stove properly [Hearth.com] How to run my Morsoe 1412 stove properly](https://www.hearth.com/talk/data/attachments/285/285466-b19644bab4348f2823e757b98895e111.jpg?hash=DaQi2jy15_)
