I'm learning how to adapt to my stove's quirks as best as possible and have gotten to the point now that I found that if I leave it around 4th from the highest or 5th, and keep it loaded no more than 1/2 of the way, I can rely on a fairly steady fire.
However reloads are a bit tricky. I find that I have to open the damper, and then set air control to max. I can only put about 4-5 pieces in or else the stove is unmanageable. (wont go into that here). The goal is to run this at 4th from the highest or 5th setting on air control therein. However to get there I have to let that new load 'catch' before switching to secondary (closing the internal damper) and then sometimes I can immediately lower the air control to 4th setting, other times I have to wait another 15 mins because otherwise the load will start to just smolder. That's a bit of babysitting but far better than Ive dealt with so far for fairly consistent 475-550 STT temps.
Recently though, I loaded in what I believe was 3 pieces of oak and 1 cherry, medium but more on the larger side. It wasnt catching after 15 minutes, so I left and came back another 15 and it still wasnt enough for me to shut down to secondary. Another 15 minutes later and the fire box was full of flames, so I quickly shut down to secondary and lowered my air control
But I started to hear stove pipe pings (and a few snap, crackle, pops). My pipe temps were at 300 above the stove about 18", then 325 a bit higher on the telescopic pipe bottom section, then 300 again about chest height. It went down from there until the first elbow, it was 290, then down again until the ceiling box, the outside of the connector was like 250. It just 'feels' scary when it gets to that temp on my IR. Maybe because my last experience with that resulting in a 'creosote burnoff' which sound like small firecrackers going off in first half of the pipe section and smoke puffing out of the pipe joints.
Is there a 'safe' temp to run stove pipe at?
EDIT: If I just shut straight down to secondary, the 4 new pieces will smolder, blacken the glass and of course they smothered/cover the nice bed of coal until they can catch and draw the flames up. This is how I keep my glass clean now and heat consistent.
Safe to assume most of that has been from hot starts before I start to choke things back down.
