Claudale said:It's a Drolet Savannah. I was expecting to get it up to 600 or more, and I am worried this is a sign of creosote build up.
Any opinions on this?
thanks
Claudale said:It's in the basement and my chimney is very tall. So I have about 6 feet of liner slopping up towards the wall and then it goes up 35 feet to the top of the chimney.
We also have a pellet stove we use 24/7, so I won't run it again until Friday (gone tomorrow), I'll take a picture on Friday of the flame.
Possibly the room does need more air, this stove does make that room hot (I've had the room as high as 93 degrees) but the air doesn't leave that room one bit - you feel it as you walk through the door (which is always wide open) - probably a 25 degree difference in temperature from being at one side of the doorway vs the next.
savageactor7 said:One other consideration Claudale ...if the blower is running that will reduced stove top temp. So you may have that hot fire you desire...you just can't prove it LOL. Here's the fix...lock down the blower to reassure yourself the wood will heat the stove up the temp you want, observe what that fire and coal bed looks like, then engage the blower and take note of the lower adjusted temp. Then relax, cause you know the stove is preforming OK.
Pagey said:I see nothing wrong with that fire.
Pagey said:If the room is 90 degrees, I would say your stove is operating fine. Like BeGreen stated, moving that air to a cooler location is another matter entirely. Basement installs are often problematic, especially in the basement is unfinished and not insulated. Basement walls will bleed BTUs almost as fast as you can generate them. Most people recommend setting up a convection loop by blow cold air at ground level toward the stove so that warm air will move in and take its place. Now, how you achieve that from a basement I have no clue. Sounds like the stove is operating just fine.
