I need help identifying a few trees
Rebelduckman
1,105
Pulaski, Mississippi
[Hearth.com] I need help identifying a few trees [Hearth.com] I need help identifying a few trees[Hearth.com] I need help identifying a few trees[Hearth.com] I need help identifying a few trees[Hearth.com] I need help identifying a few trees
In Mississippi if that helps any. Tia
I'll take a stab...
1. I dunno
2. likewise
3. poison ivy growing on some tree I dunno the name of....but maybe white oak
4. some kind of hickory - maybe pignut
5. looks like some kind of maple
#1 My guess Gum(really do not know)
#2 Cherry
#3 Hickory
#4 White Oak
#5 Soft Maple.
Bark id alone is pretty difficult. #1 is almost certainly walnut. #2 most likely cherry. The rest I need more info else I'm just completely guessing
Picks of Canopy or at least some foliage needed
If your on a flood plain: My guess
black gum - sickly subcanopy tree
black cherry
black gum with poison ivy vine - growing well as canopy tree
swamp chestnut oak or white oak: acorns - 12 grams vs. 3-5 grams usually found under leaf litter unless the hogs already discovered them
red maple or swamp red maple
black cherry
I could see #3 as gum as well. Wasn't thinking that but it sure is a strange look for Hickory.
"Picks of Canopy or at least some foliage needed"
Rub the bark, if soft, small pieces will rub off like the other soft barked gums. I like to describe hickory bark as tight and hard.
Thanks for the replies men. I'll try to post these again in the spring so you'll have a little better idea of things
Reactions: blazincajun
The second one I would say is black cherry as I do not know any other tree that has bark similar to it. I am three states to the north though so I have no idea what kind of "tropical" trees grow your way.
[Hearth.com] I need help identifying a few trees I cut up some of #5 today. Sure does split good. Very pretty wood. You guys say maple huh?
Yepper
Thanks for clarifying. I'm still learning the trees. Until I got the stove this year pretty much all I knew was oak. Came up with a fireplace in the house and wood didn't necessarily have to be seasoned to burn. I found out real quick this year I better find some wood that'll season much quicker. I have a couple years worth of oak but it'll need to set a couple years.
1. Maybe a Hawthorne?
2. Black Cherry
5. Does look like soft maple.
Silver Maple...softer of the Maple, but still good wood
Hawthorne isn't all that special. It seems soft, very moist, and everyone I've cut has had ants living inside of it. This was on a fence line I was clearing for my uncle. The trees were not all that old or large and they seemed healthy so the ant thing had me baffled.
