ICC Excel metal roof flashing for 6" duraplus
bkoltai9
23
Oxford, MS
Hi everyone,
I'm purchasing parts for 6" duraplus chimney and I've read that the best flashing for my metal roof is from ICC Excel.
I was preparing to purchase part 6EMFA (for 6" chimney) which shows a hole diameter of 8.375", which I assume matches the OD of their chimney.
Should I be using part 8EMFA (for 8" chimney) to match the OD of 6" duraplus that I think is 10.375"?
Thanks for your help!
Hi everyone,
Don't get duraplus. Spend the little extra and get insulated doublewall stuff. It is far better
Reactions: webby3650
+1 go with DuraTech instead
I intended to use duratech, but I purchased a duraplus transition anchor plate 5 years ago and now it's installed. Unfortunately I'm committed at this point.
If your stuck with duraplus, then just get the flashing for an 8” chimney, you can trim it a little if needed. Just be certain you still have the proper clearance to the roof deck.
