My 1970s house has a Heatilator built into the fireplace. It has a small fan that blows into a large open area, then eventually into some pipes that exit the top of the fireplace. It seems that if I got more airflow into the pipes at the top, I would get much better heat transfer from the fireplace into the room. I have pretty limited access to this space without tearing apart alot of the rock facing. I think if I can get a flexible tubing that would attach to the fan, I could then exit the tubing near the pipes at the top of the fireplace. This would force alot more air through the pipes at the top, extracting more heat.
Here's my question- what type of flexible 3" or 4" piping can I get that will hold up to the heat of the fireplace? This old post of mine has pics of my fireplace.
Thanks!
www.hearth.com
Thanks!
Older fireplace with built in fan and tubes
I just moved into a house that was built in the 1970s. It has a good size fireplace 33wx27hx24deep with some tubes that run through the back and top of it, to blow air out the top, via some cutouts in the fireplace facia. It has 2 small fans, one on each side, on the bottom of the fireplace. One...
