Hello! Long time lurker, first time poster (thanks for the wealth of info I've garnered from this site)..
Recently moved into a new house with two fireplaces, one in the basement the other on the main floor. Basement fireplace is used often as that's where I spent my time. The main floor fireplace, IMHO, is more decorative than functional and I would like to make the main floor fireplace functional by installing an insert. It will make a tremendous difference in heating costs as the main bedroom is an open loft pn the floor above the main fireplace. Previous home had a Jotul 550 which served me very well so I was leaning towards that, but I'm open to whichever insert will fit my situation.
So, armed with pics and measurements, I went to the local fireplace dealer/installer and asked for their recommendation. Their answer was a flat "We can't help you," with no explanation. Even after inquiring as to why not, I got the same answer.
My question is whether installing an insert is possible or should I not bother wasting my time?
The fireplace is double sided with a measurement of 33" between the front/back openings. Height and width are 24" (H) and 33" (W), and the fireplace is 28" off the floor.
I realize two sided fireplace inserts are very uncommon, so i would like to go with an insert on one side and a screen on the other side. Is the height off the floor going to be an issue that would preclude a heavy insert from being installed? Is an insert possible or am I hunting for a unicorn?
Below are pics of the functional basement fireplace, the main floor fireplace and the chimney in hopes that it helps you. Above all, thanks in advance!
Basement fireplace:
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165956-8121a37fa27a69a3ec0a05222ac56b1c.jpg?hash=7Cv1tgqEYS)
Main floor fireplace pics:
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165961-ae7105df1df7c1195a8b17aaea867f68.jpg?hash=e_Aws8zH0L)
Chimney
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165963-0bf053f98fed0758b0d75caf38428ef3.jpg?hash=c4-YGDiQW2)
THANKS in advance!
Basement fireplace:
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165958-ffbf35ba2de40cc778ce688fc2012c4b.jpg?hash=Hj0inNtDIZ)
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165959-4bf2a89ef6197ebca234c331b4349e7a.jpg?hash=hKdncKY2qP)
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165960-5e1c1f174aaba973bc68965a5ff3e13f.jpg?hash=_Ue4almmbV)
![[Hearth.com] Insert in raised existing wood fireplace advice. [Hearth.com] Insert in raised existing wood fireplace advice.](https://www.hearth.com/talk/data/attachments/165/165962-276a197bbcef3560071599339a94aeed.jpg?hash=NQbCZ88BAu)
Chimney
THANKS in advance!
