I have an osburn insert, inside a masonry fireplace, fully lined Stainless Steel chimney with no lower blockoff pate, but of course the top late sealed off.
I did a little experiment tonight. I was running the blower fan, which dosen't push alot of air. So a stuck a small fan near the side of the stove, blowing in the side air caivity..mine has the space around the top, and two sides that the surround wont cover. Anyway I got a little more air movement.
I pulled the two side surround pieces off, left said fan there running. The heat movement I got was amazing! So much that it turned the ceiling fan above the stove, that was not turned on. It seems that some of the bricks around the fireplace are warm..not HOT, but warm...I wonder if i'm pusing some of that heat around??
So I seem to be getting alot more heat without the surround on the insert...do I NEED to put the surround on? Or is it more for looks...Thanks!
