Hello,
As the title states I'm installing my jotul 3 into my fireplace and I have some questions. First off I will give you some background on my house.
Built in 1987 center hall colonial. In an area where there's only propane or oil heat. I'm lucky to have propane... At least for cooking I am. I have a Vermont castings in my family room off my kitchen which is on the right side of the house and I have a traditional masonry fireplace on the opposite side of the house in the living room.
First question, should I install the insulation over the flex liner that I'm connecting to my jotul? Is it worth it, the run from the fireplace to the chimney top is about 22 feet.
Second question, do you think having two, one on either end of the first floor of the house, is overkill? Do you think running both will substantially reduce my propane bills? The house is roughly 2800 square feet and each by themselves are rated to heat up to 1400 square feet. The house is pretty well insulated. This will be my first full winter in this house and propane is ridiculously expensive in NW NJ, around 4 times the cost of natural gas.
Third question, is having this jotul in a masonry fireplace safe? I'm nervous about leaving it burning over night. How warm will the second floor get? I live at about 900 feet above sea level which isn't that high but I did have about a dozen days last winter that were only in the single digits. This jotul is in like new condition as well, I replaced everything inside the fire box such as the burner plates, log retainer, glass, and all the gaskets. Any thoughts or suggestions will be greatly appreciated.
