I have a full walk-out basement, approximately 2500 sq ft of un-finished space, the walls are poured concrete and I am looking to install a PE Summit insert in the masonry fireplace for additional heat as we use the basement a lot and hoping some of that heat will migrate upstairs during the winter months. My fireplace and chimney are in the center of the house and my question is this: will the un-finished concrete walls and floor soak up all the heat the insert will put out? The temp in the basement in the winter stays about 60 degrees and oddly, it gets quite warm in the summer. I would appreciate your thoughts, advice and experience from those with supplemental heat in their unfinished basements.
Thanks in advance. So much great info on this site!
