I'm no insert expert...I've only had experience with the Buck 91. Inserts are a bit more expensive than free-standing stoves, and you are limited as to what insert will fit...32" is kind of narrow I believe, and you must also take into account if the fireplace narrows as you go back into it, or gets shorter in depth at the top. The size insert that will fit will determine if you are able to get the overnight burn you want. Go to the makers' websites to look at the manuals and see if the inserts will fit. The last ones begreen mentioned, the Enviro and PE, are going to be mid-priced as opposed to the ones he mentions in post #23 which are "value" offerings. If you can find dealers like farm stores, Home Depot or Menards you might be able to at least look at the brands, if not the particular inserts in question. Even the value stoves should last more than 5 years but if something does go wrong, parts may not be as replaceable as on a better stove. I think you have a Napoleon dealer...that Timberwolf insert might be a little better than the most basic inserts. I think you have a Pacific Energy (PE) dealer not too far. It helps when you can look at products in person to educate yourself, but don't expect that a dealer will necessarily know very much. Use the search function under "forums" at the top of the page to investigate stoves that might interest you.yes this will be a insert for sure....I am really looking for something that will last. I don't want to be pulling it out in 5 years and saying well there went a 1k on that and having to buy another. But what are the best lower brand stoves I've got 32w x 27h x 30d.
Yeah, you may have made a small mistake buying that stove. Unless you need a huge stove (big house,) you don't want to invest in an 8" chimney so you are back to square one, looking for a new or used insert with a 6" flue exit. Keep an eye on craigslist (Charleston?)...maybe you can get lucky. But as we said, buy new and take a $300 rebate off the bottom line of your federal taxes next year. You may be able to get your money out of the App. stove, or at least some of it...I payed 200 for the one I got now. Could my money be recovered if I try to sale? I would love to find a used one but I know I'm looking around at the wrong time of the year.
I think the only insert they offer is the 13 NCI.What Englander model?
Did you check weather they will both fit? Looks like the 1800i needs 28" width at 18" back into the fireplace and 23" high. It appears to have a bigger fire box than the Englander, so may do better on overnight burns. There are several here that have the Englander 13-NCI and I seem to remember that overnight burns were not easy to get. Are they stocking the inserts locally, where you can go look at them up close? You have a Napoleon dealer nearby as well, correct? I wonder if they have the 1402 insert and the Timberwolf insert in stock...might be interesting to see what the extra money would get you. Of course you can go as cheap as possible now to get up and running and be set for many years, then kick back and research the higher-priced inserts to see what you might want as your bucket-list stove down the road. You might even find it used or at close-out, etc.Well thanks for all the help. Looks like I am leaning towards the drolet 1800. So far I haven't read a single bad thing plus I can get it local. It's really a toss between the England'er or the drolet. Does anybody have any experience with ether one
"This holiday season, give the gift of heat."holidays coming up.
The rebate is through the end of this year...not sure if it will be extended in 2017. (broken link removed to http://woodstove.com/tax-credit-faq)Hey before you order anything, is that insert going to be large enough for the space you want to heat.. don't for get masonry absorbs heat also.
Good deal. Sounds like there's enough there so that you can get a few years ahead. Then you know everything will by dry enough to burn well, even Oak. But right now I would concentrate on getting wood that's dry enough to go into the stove right away. Find as much as you can of small, dead trees, either standing or down, that all the bark has fallen off. Most of that stuff will be right around 20% MC.Going after another load this weekend.
