insulated double wall stove pipe as thimble?
Kevin777
11
New york
I was reading a piece on heath.com and it said NFPA mentions something about using an insulated double wall stove pipe as a thimble. Here is the reading. Would this be up to code if I had the proper amount of air space? My masonry chimney is on an exterior wall. covered in plywood. The old thimble was clay and had a 2 inch clearance to the plywood, which I have been told is crazy and unsafe.. I cut out as my much plywood as I could and the width of the chimney is only 15 5/8'' wide. If I cut any further ill be cutting into my siding of my house. The heat fab saf-t thimble which is meant to go through a combustible wall says that the clearance needs to 16''wx17''L...however I don't have that much room. The insul flue mentioned in this writing is the same. I just don't have enough clearance and I don't know what to do https://www.hearth.com/econtent/index.php/articles/passing_a_chimney
"An alternate method is also mentioned in the NFPA guide. In this case, a section of insulated, double wall chimney is used instead of the crock…and an airspace is used around it instead of the solid brick wall patch. This involves a 9” airspace, so the total rough framing would be 26” square, and once again cement board could be used to bring the wall surface with up to the insulated pipe."
Double-wall stove pipe can not pass through a wall. Double-wall, class A chimney pipe can. They are two different animals.
Reactions: Kevin777
Great! I just want this to be done and over with and safe! I have a ton of black walnut, and cherry I am looking forward to burning this year, if this damn thimble situation can get fixed. Thanks begreen!
