Hi all,
This forum is really great for a new guy like me about to buy his first stove. I've learned a lot from hours reading the posts, but I don't find the answer to this particular question...I will be installing a free standing stove in the interior 15' masonary chimney of my 1965 house. Planning on putting a 6" insulated liner into an 8"x17" tile flue through a 6"x28" damper opening that I have already removed the rusted out damper plate, hinge, and handle bracket. Also planning on putting in a block off plate as so many recommend.
So...I'm curious about the terminating ends of the insulation. At the top, I understand the insulation should go right up to the weather cap, but at the bottom end, where should the insulation end? At the top of the block off plate, or pass through that plate and get down around the flex connection fitting to the stove? I read posts about caulking/fire cementing around the liner/block off plate junction, but never have seen any real detail about this point. Seems like you couldn't get a seal there if insulation was around the liner coming through the block off plate. Thanks...
