After running my Harman TL-300 in an uninsulated home(1 Side of a duplex) under renovation until last week. It did a great job considering there was 0 insulation. But i dont run the stove 24/7 and in the morning after the stove burned through its load of wood the night before would see temps in the low 40s. Last week i insulated with cellulose top to bottom and now when i run the stove at the lowest setting its still keeps the house in the 80s and the next morning with no fire at all the house will maintain around 60 gradually dropping into the second day with no heat im down around low 50s.
With outside temps 15 at night and 25-30 during the day its amazing to me it takes 3 days to cool down with no heat.
Granted i get some heat through the wall from the other side of the duplex, but not much. Hpuse is about 1200 Sq Ft
IM sure i will have to open some windows to keep the house from overheating if the outside temp goes over 30.
Insulation makes all the difference.
I too have double pane low-E argon windows. They are pretty good! Mine also open on a crank, not a guillotine type: if the window can slide, air can pass. The crank ones are TIGHT when you pull them in and lock.
