I will be installing one of these this fall. I'll be sure to let you gents know all about my experience, which has been very positive so far(ordering from Rainer.)
tickbitty said:Hey there! Been a while, but thanks for that. I have been very pleased with the product and feel it was a great choice for my application and a great value from you. Yes obviously when pressed I didn't have the paperwork to back it up but I wouldn't be using it if I didn't feel it was safe. I am glad you found the thread and updated it though, because I think this is great stuff and I am happy to see the follow-through!
CleanBurnin said:Rainier
Thanks for posting the instructions. There are conflicting statements in them that either got missed in the editing process or are just actually conflicting.
In the "Application" para, it mentions that the insulation give the liner a 0" clearance to combustibles, but in two other paras, one on each page, they state that NFPA 211 clearances apply to combustibles external to the chimney apply.
So, can this product be installed at zero clearance to combustibles external to the flue or not? A straight answer that demonstrates the integrity you represent is appreciated
Brent
TheHeatElement said:Brent- I wish you could relate to the industry, the liner is their for the chimney to fail - the chimney is in place for NFPA regulations.. and if you look through simpson duravent or selkirk or Don park, or any other chimney liner manufacturer you will see that they recommend insulation in their liner kits but normally don't offer them.. We only offer it as a means to a soluble end...
TheHeatElement - 26 October 2009 07:26 AM
Our liners are already tested to 0” clearance by warnock and 1” clearance by UL with the insulation you get 0” clearance. It’s a great system that allows the installer to unroll and install no more applying insulation on the ground in front of the home. I have another product for corn stoves.. but it’s hush hush right now.
<blockquote>jtp10181 - 26 October 2009 07:11 AM
Thats a great idea. The alum outer should protect the insulation a lot better than the SS mesh.
I assume its tested to UL1777 and passes by itself for 0 - 0 clearance? </p></blockquote>
MAGNAFLEX INDUSTRIES INC MH17674
211 WINDSOR DR
MT STERLING, KY 40353 USA
Model A2 chimney liner system, sizes 3, 4, 5, 5-1/2, 6, 7 and 8 in. diameter. Intended for use in masonry chimneys used to vent gas fired appliances equipped with draft hoods and appliances intended for use with Type B gas vents. Maximum installation height is 60 ft.
Model LW chimney liner system, sizes 3, 4, 5, 6, 7 and 8 in. diameter. Intended for use in masonry chimneys used to vent gas or oil fueled appliances with a maximum continuous flue gas temperature of 500 F above ambient. Maximum installation height is 60 ft.
Minimum installation clearance to combustible construction from inlet of liner system is to be that which is required for the type of vent connector and appliance being connected to the liner system - .
Model Mirror Stainless Flue chimney lining system in sizes 5, 6, 7 and 8 in. nominal diameter for use in masonry chimneys for maximum chimney heights of 80 ft.
Minimum installation clearances are 18 in. to combustible construction from the tee section chimney connector inlet.
Last Updated on 1994-06-09
