Pipe install is done and I'm in nealry done with the finsh work on the hearth pad and I want to be sure of something before I ruin my stove.
There is a sheet of white insulation that is at the top of my firebox (Moros 3610). I see it in my parts diagram, but I want to make sure its properly mounted in my stove before I do any serious firing. We had to use the stove Saturday morning because the alternative was to turn on the furnace...and I refuse to turn on the furnace for anyhting other than hot water in late June. I noticed that whenever I wanted to add wood once the fire got going (we kept it small and moderately warm so as to let the gaskets settle and to allow the exterior outgassing to take place and not suffocate us) through the side door that a significant amount of smoke would pour into the living area. I've managed to convince myself that the insulation either needs to be removed because its for shipping or that its not mounted properly and its blocking the outbound airpath, thus when I opened the door the smoke just takes that path of least resistance and goes out the door instead of up the flue.
I've enclosed a couple shots below for reference. One is a closeup from the base of the front opening and the other is the same shot from a short distance. Should it be right there or is it supposed to be up higher? Why would you want insualtion iside the stove anyway? Isn't that counterproductive? Or is it more of an air filter than anything else? Is there a detriment to its removal?
Thnak you.
Thnak you.
