Hello, all,
A few months ago I found an old Intrepid 1 and fixed it up. I had a Jotul 602 in the fireplace and it's a great stove, but I've always liked the look of the VC stoves and the open fireplace feature.
Anyway, the Jotul burned like a forge-- tremendous draft, I started every fire with one match and it cranked! It warmed the room in no time and, though it consumed a lot of wood, it was very simple to control.
Not so the Intrepid... I'm having a lot of trouble getting it to behave.
I did add a 90 degree section to the pipe, but there's otherwise no difference, and before I connected the stove I could feel air being sucked into the chimney, so I know the pipe is drawing just fine.
However, even if I let the stove burn through 2 loads with the doors either cracked or wide open and the damper and draft flap in the rear open, it doesn't roar the way the Jotul did.
I also can't close the doors or the damper without the fire just going out... even though the draft flap is wide open.
I don't know what's causing the problem. I pushed a wire through the rear flap opening to make sure there was no blockage, but still the air tubes are obviously not working.
It's pretty frustrating... any help from more experienced members would really be appreciated.
Thanks,
Andrew
Thanks,
Andrew
