Sorry for the long winded thread on this but trying to figure out why the glass smokes so bad on this stove when it seems to function okay otherwise. The manuals are no help with this. This seems to be a common issue with these stoves but why? The stove as an air wash system for the glass. Why is it not working? My thoughts are as follows:
1) The air wash flow is compromised by having the primary air volume split between the combuster and the air wash so already 50% less going to the air wash than what's going into the stove firstly.
2) The air hitting the glass doesn't get sufficiently warmed up cooling the glass and thus promoting the soot/creosote formation on same.
3) Insufficient draft to the stove. Installation manual says minimum of 0.03 inches H20 to operate properly. That's not much draft.
4) MC of wood too high?
5) Stove not hot enough
6) All of the above?
I'm using wood with a MC of <16%. Think my draft is sufficient but getting a manometer to check that. Run STT around 400 cat temp 1000 doesn't clean glass off. Still not hot enough? Glass temp with IR gun is around 500. I have an OAK attached to stove but maybe that's cooling the primary air too much? Maybe air wash ducts partially blocked? Don't see how thats possible but I guess is a possibility. May remove those airwash manifolds in the near future to check. Any other thoughts or if someone as gotten the stove to keep the glass relatively clean I'm all ears. Thanks.
