Invincible T Burn pot troubles
xNOCx
33
Bath, Maine
I have a 92 Invincible T and its not keeping the pot full and burning back to the auger. I have tried adjusting the auger and will keep it full if i burn at a heat setting of 4 and up for an hour or so then it creeps back to the auger. I have checked to see if i am getting air from the hopper but opening the lid doesn't change the flame. checked the door seal, motor seals, cleaned the heat exchanger tubes and vacuumed every nook and cranny i could get too in the process, the flame guide is in good condition.I have cleaned the crap out of this thing and its still doing it. is something misaligned? can the burn pot be removed and reset or is i welded in place? is there a gasket there?
Here is a little back history on it. previous owner never cleaned and control board has been replaced, the burn pot was full of charcoal cooked into the pot and all holes at the edge of the burn pot were blocked. chipped out all the crap and cleaned the holes. cleaned out inside the burn pot where the blower pushes the air to the holes. puts out heat like crazy but want proper operation. thanks
You are going to want to pull the stove out and remove the auger assembly. Once out, I bet that you have creosote and fines debris clogging the feeder drop chute. if so, it's a bear to clean that out properly. 10 hrs of work the last time I deconstructed the weldment to remove it and clean. I betcha that's it. Do you have inconsistent feed issues??
Thank you for your quick reply
Yes I have inconsistent feed all the time.
I will remove it this weekend and start the cleaning process.. are there any gaskets or replacement bolts or other parts I should get ahead of time?
OK so I've taken the burn pot out, the auger assembly out, disassembled the feeder and cleaned the drop chute, yea that was quite a pain. I only had a small amount of buildup but i got everything off to bare metal. resealed and tested but its still pulling air through the auger. I put some ash at the bottom of the pot and some at the top. I clearly have better air flow at the top of the pot but it seems like the primary source for air is still the auger. I have the damper on the bottom of the pot totally closed and the draft setting is as high as it can be (factory) according to the manual... I did a test burn with 1/3 of the hopper refilled and still not seeing the pellets feed the amount it should. I set my temp on 5 filled the pot right up, opened the feed to 8 turns. i would have expected the pellets to overflow but didn't. after a half hour i added another turn but made no difference. I see the auger is on pretty consistently when burning its just not feeding enough. I'm at a loss here. should i start thinking about replacing the esp?
Possibly fixed or atleast fixed 1 part of the problem. I had the bright Idea of using duct tape on all sealed seams on the harman. then i put a small mound of ash right infront of the auger. pressed the start button and poof all the ash few away. GERR.. so now what? rechecked all seals. Grabbed a candle and lit it and blew it out and then used the smoke to follow where the air intake problem is... by accident i found the leak on the door of the hopper. I opened the hopper lid and felt down by the feed block and clearly sucking air. then I noticed there was adhesive remains arround the edge where the hopper lid sits. So i am calling the local harman dealer to ask about a seal. feel stupid for missing that one. so i duct taped the lid and put more ash infront of the auger and pressed the start button and it stayed, opened and closed the door a few times and stayed... well atleast I know this baby is clean and now after i get a gasket/seal for the lid we will do a test burn. I am praying this will fix my feed problem by controlling the air flow but maybe i am being to optimistic
Guess we will see
I have the same stove as you, a '93 model. I got it last spring and after replacing the ESP I'm just now getting acquainted with it, and how to adjust the settings, etc. So far I'm very impressed with the heat output. Tonite it's burning nicely on a stove temp setting of 2 1/2, with a feed rate of 5 1/2 turns. You mentioned that your flame doesn't change when you open the hopper lid, and that your hopper seal may be leaking air. When I open my hopper lid the flame leans towards the front glass and a lot of sparks are generated, so if yours wasn't sealed properly I would expect you would see this same type of flame. I think you could save yourself some $$ by replacing the seal with some 1/4" closed-cell foam weather stripping, rather than going to a Harman dealer. Just make sure the seal is continuous at the corners when you stick it on. Good luck.
Guess we will see
That was some fine detective work. But it really is a win/win. Fixed the problem, probably cost you VERY little money, and you won't have to clean that area of the stove for a long time. Well done.
OK looks like that was only part of the Issue. I still see the flame crawl back to the auger and a CLEAR difference with the new seal for the hopper lid. I checked my gasket and fixed the area it was leaking. but its still burning back to the auger, it takes a lot more time but the majority of the flame looks to be coming from there instead of the leading edge of the burn pot. is this normal??? I am suspect of the glass gasket of the burn pot since when I took it off haft the gasket stayed on the pot the other in the stove but put back together would still be complete. I also noticed at the top of the hole for the auger on the burn pot there is a slit in the metal is this by design or is it just cracked from extensive heat from a dirty stove over a long period of time. what do you guys think?
I'll take some pics and post them tomorrow.
Ok no pictures flame was too bright to show what I am thinking is a problem. soo I used my wonderful artistic abillitys and MS Paint to make an illustration
  • [Hearth.com] Invincible T Burn pot troubles
xNOCx said:
OK looks like that was only part of the Issue. I still see the flame crawl back to the auger and a CLEAR difference with the new seal for the hopper lid. I checked my gasket and fixed the area it was leaking. but its still burning back to the auger, it takes a lot more time but the majority of the flame looks to be coming from there instead of the leading edge of the burn pot. is this normal??? .
With what you are describing it does seem like it may be normal, if I understand right. It sounds like you fixed the hopper lid leak... and the way to confirm that is burning with the lid closed.. and then open.. and observing a noticable change between the flame.
As for the burn pot... my experience is that flame should be coming from the back of the burnpot since the majority of the fuel is fed there and the deepest collection of pellets will stay there... in other words the collection of burning pellets vs ash should be from back to front Pellets then ash... If you have ash collecting against your auger during operation or are getting a layer of ash->pellets->ash then I'd be concerned. if its just Pellets right up against the auger burning like blazes and ash collecting on the ouside of your flame, then its normal as far as I'm concerned.
The only thing that I would question is if your feeder is working is too slow if you are not getting at least a good 3-4 inch wide collection of pellets burning when wide open. For me, wide open feed settings and stove temp mode up as high as it will go, I still don't lose pellets out the burnpot... I end up with an impressive 6" pile of pellets burning like crazy.. but it seems the more pellets that end up in the burn pot.. the more it will burn.
That is fantastic!!!!
Brown is unburnt, Red Hot pellets, yellow flame.. Is the Ash all collecting in the right of your drawing?.
yes exactly. ash is collecting at the end of the pot and not ontop of the pellets, i was just concerned about the burning of pellets going into the auger. I feel much more confident in the stove now. I was racking my brain trying to figure out what I missed. Thank you for the quick replys guys.
HI Tim, I have a 92 or 93 Harman T and have been having heat output issues. I've been reading the back you issues of the forum and discovered your posting above. Are you really experiencing all that heat at a T setting of 2.5 and feed rate of 5.5? I have my stove T on 7 and feed rate at 5 and it's still totally lame in terms of heat output. I have a new motor, new distribution fan, new esp fully cleaned out the horizontal chamber and the two vertical chambers. I've read a post where the burn pot was removed. I never did this, but after removing the two mounting bolts of the burn pot I can't seem to pop the burn pot off from the main stove body. any idea how to get the burn pot off and why the stove is lame for heat? I do have to prop the hopper lid open with a pellet to get a tight flame. Otherwise, the flame is lazy. I've tried everything! Thanks Brian
