I have a stove top thermometer on my blazeking princess insert, placed directly in center of stove. When its 10 degrees out I have to keep the stove around 600-700 degrees in order to keep the house room temperature. Is 700 too hot ?
That's the important thing to watch. I would ask Blaze King how running it at max will affect the cat life. It may shorten it.
I don't know why you think the cat probe thermometer is so useless? If it's pegged, it's maxed out! It's not good for it to run at these temps for very long. There are no temperatures marked because the actual temp is of no real concern for most customers, it would only scare them. It's very responsive, tells you when the cat becomes active, and how "active" it is, which is determined by the setting on the air control. If it's pegged, turn it down. I don't see how it's useless? It's actually quit nice!I disagree. The cat probe reading is of little to no value other than to tell you when the cat bypass may be engaged. That's why there are no numbers on the dial. The user has very little control of cat temperature. I am on my third year with my current cat element and I can still bury the needle past the active range on that cat meter.
Don't you folks think that the thermostat on the BK is intended to limit the output to a safe stove temperature? My BK will run up to 650 Stove top temp and then stop rising when the stat is set to 3/3.
?I disagree. The cat probe reading is of little to no value other than to tell you when the cat bypass may be engaged.
So you think leaving it pegged is ok? I sure don't.
The thermometers sold to our industry use the same design for movement, a bi metallic spring, as the cat therms. The reason we dropped the numbers is PRECISELY due to this type of confusion.So is it ok to run the stove full blast with the cat probe maxed out? Does it shorten the life?From New Zealand! FirstThe thermometers sold to our industry use the same design for movement, a bi metallic spring, as the cat therms. The reason we dropped the numbers is PRECISELY due to this type of confusion.
Take the stove top thermometer, place it in your kitchen oven, set it at 500 and read the thermometer. There can be great, huge and significant swings in accuracy.
Back to the beach!
Of course it will run wide open! It's hard on the cat to do this all the time.If it won't run WFO , I would junk it. Not something I would want in my house.
Run it wide open....but make certain door seals a good....So is it ok to run the stove full blast with the cat probe maxed out? Does it shorten the life?
Agreed. Continually wide open means your house insulation needs review. No stove is intended to be run 100%, 100% of the time.If I would've run my Lopi wide open it would've been a puddle of steel on the floor. Who runs a stove wide open on purpose? If you have to run a stove wide open it's not the right stove for the space you're heating. The other side of it is running a stove wide open is not very efficient, wasting lots of heat up the flue.
That's what I meant...Agreed. Continually wide open means your house insulation needs review. No stove is intended to be run 100%, 100% of the time.
I have a few service calls who run this way and they blow through a cat every 2 years with a good door seal.Run it wide open....but make certain door seals a good....
On the cats I've run (Dutchwest, Woodstock Fv & Ks, and the Buck) I can control how high the cat goes by the air setting, what kind of wood I've loaded (higher BTU gasses slower) and by how much I've burned in the load. I doubt that the BK is any different but I could be wrong.The user has very little control of cat temperature.
Manuals are by no means the be-all and end-all of stove operation, as anyone who has had much experience will tell you. They can hardly be expected to go into much detail on the finer points of running one; Their aim us to just convey the basics, and sometimes they don't even do that very well.The owner's manual, written to tell us definitively how to operate this stove, does not tell you to use that meter for anything except engaging the cat.
"Monitor catalytic temperatures:. A catalytic meter will tell you when to engage your combustor, when to turn down your stove, and when your combustor needs to be cleaned or replaced. It signals when to avoid damaging catalyst at temperatures exceeding 1500° Fahrenheit (1050° Celsius)." http://www.woodstovecombustors.com/maintenance.html[/quote
1050C = 1922F, Those temps for extended perods are pushing the Cat a bit. Cat's love 1500F, right in it's happy zone.
