I am seeing similar results. The Condar probe will eventually equalize, but it is typically under by about 100-150º. It's a mild day and I built a partial fire this morning. Currently, the Condar is reading 225º with the fire in the coaling stage. The Auber is reading 349º. SST is 380º.Ok, so to verify the Condar's temperature I inserted my professional cooking probe into the flue. That's precise to about a degree or two.
Turns out that when the Condar shows 200F (as far as a correct reading is possible there), the real flue temperature is around 320F.
So well above the boiling point of water, but then again the probe location is only 2 feet above the stove, and the temperature will drop further along the flue...
![[Hearth.com] Is a stove top thermometer enough or do I need a flue thermometer as well for my new GM 60? [Hearth.com] Is a stove top thermometer enough or do I need a flue thermometer as well for my new GM 60?](https://www.hearth.com/talk/data/attachments/267/267691-2dcbe226d6ea9c4b008f3d7a5648fc50.jpg?hash=r13UqodQrV)
